drums
drums
my buddy has a 78 nova. yesterday we were goin to do the rear brakes and we couldnt get the drums off. we tried everything we could think of from pb blast to beatin the **** out of it. It loosened up alittle but no dice. it felt like the drum was gettin caught up on something ( probably the shoes ). We tried to get in there and move the adjuster but it was some kind of weird setup and we couldnt move it with the bent up screwdriver. then we finally gave up, any help appreciated thanx.
is the e brake set? might want to let it off if it is. other than that i always use the BFH method.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
opps double clicked
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited March 18, 2001).]
ICON Motorsports
1st & 3rd
JH,
One way or another, the drum will come off. The easiest way it to get the shoes backed off. Remove the lid of the master cylinder to allow fluid to return to the reserviour and overflow if necessary to retract the wheel cylinders fully.
If that isn't possible, you can remove the heads of the shoe anchor pins from the backing plate with a grinder or chisel. The shoes will then flex outward more, allowing the drums to clear the backing plate enough to release the lower adjustment screw. The process can ge tedious, and you'll need new brake anchor hardware (which isn't a bad idea anyway).
Remembering stuff like this makes me appreciate four wheel discs on all but two of my vehicles - even though the older calipers are no treat, either.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Later,
Vader
Car: 82 camaro SC
Do what vader said, grind those pins off, or use a chisel on them. I just bought a rear brake hardware kit for my 1991 s-15 jimmy, it cost 3.99 and included the hardware for both sides. I would guess you have some big grooves in the drums. You may need to buy some new ones.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Prodigious
Sep 18, 2015 05:23 AM
Prodigious
Sep 18, 2015 05:18 AM
