Your thoughts please.
Happy to say my car is running well EXCEPT:
I've got a slight hesitation just past idle when slowing getting on the go pedal in neutral. Car hesitates and the rpm fluctuates. Otherwise, I've got good power right up to the redline.
Possibilities?
-I've checked for false air and it looks good (maf setup)
-IAC messing up (how much are these new)
-Injectors going?
-Fuel pump? (filter is new)...so is cap, rotor and plugs and TPS set properly
Thanks all
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
[This message has been edited by Steve89GTA (edited March 15, 2001).]
Possibilities?
-Injectors going?
Thanks all
89 GTA G92
Jet Airfoil
K&N Airfilter
When my fuel pump went out, the symptoms were quite different from what you are describing, so I would bet that is not your problem. It could possibly be your fuel filter, they are inexpensive and easy to fix, I got a Napa Gold Filter and it works great. I would check to see if you have any vaccum leaks, and also look at your plug wires, since you didn't mention those are new. Also, if it is your IAC, it doesn't need to be replaced, it just needs to be adjusted, and there is a tech article about it on this site.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
L98 TPI 350 (5.7L)
Definetly clean that IAC!! My car was doing the same thing until I cleaned it!
92 Z28 5.7
Trick Flow 23° heads, XR270HR-10 cam, Accel intake base + ported TPI, TES headers, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
92 Z28 5.7
Check out Truspeed
Blade, can you give me a quick rundown on how to clean this thing. You didn't remove the TB did you? I guess it's in my Hanes manual (right along side looking for the fuel pump fuse...he he).
Should I take the housing off too? Can I use Throttle body cleaner?...phew..sorry about all the q's!
Well, I removed the throttle body tubing that leads to the TB and grab the IAC with my bare hands and the thing starts to turn! Must have come loose. 13ftbs, that's all I have to torq this thing down to? (after 89, I think they changed the style). Anyway, I tightened it to 15ftbs and put some RTV blue silicone around the gasket to help it seal better. I think my problems are gone!, thanks all.
BTW, I cleaed out pintle and passage from the TB to the IAC assembly.
[This message has been edited by Steve89GTA (edited March 19, 2001).]
Elephantismo
Feb 13, 2019 12:51 AM
Jonesyfxr
Sep 26, 2015 02:08 AM
