Oil Pumps
Old Mar 17, 2001 | 05:15 PM
SCRA rules!'s Avatar
Oil Pumps
What's everyones opinions on different brands? I know the Mellings are supposed to be good, but why are they so much cheaper? I've used one in the past and didn't have problems. What do some of you get for pressure at idle with the Melling pumps-stock and high volume psi numbers would be great. I currently have a Federal Mogul 224-4143 pump and don't like it. Thanks.
'93 2wd truck
408 sb, vortecs, 454 TBI, Comp Cam, dual exhaust
Old Mar 17, 2001 | 05:31 PM
ede's Avatar
ede
not a better pump than a m55 melling, use a #26 spring in it, from mr gasket. unless you have a real need standard volumn is is all you need.
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited March 17, 2001).]
Old Mar 19, 2001 | 09:31 AM
Beefy89's Avatar
It's a good idea to take the gears out and wire brush them before you install the pump,because sometimes there are burrs left on them from hobbing the teeth.
We need Perry Mason
Old Mar 19, 2001 | 11:19 AM
82camaro's Avatar
Car: 82 camaro SC
why don't you like your current pump?
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 19, 2001 | 11:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I do exactly the same thing as ede...
What's the matter with the F-M pump?
ICON Motorsports
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
