NEED SOME HEADs
NEED SOME HEADs
I found that I can get heads at a decient price threw Auto Zone. They are stoch tpi heads. Just wondering what the best stoch head for an lg4 would be and would fit.
Livin the hot rod dream, one day at a time.
lg4
slp muffler
pro flow air cleaner
performer intake
more to come
lg4
slp muffler
performer intake
more to come
If they are TPI Heads from a 305 they will work. If they are from the 350, the valves will be too big. You might want to port and polish them too, if you have a dremel, some extensions with various grinders and sanders you can port the heads yourself, and there is lots of room for improvement on heads. I do know that the TPI heads from an LB9 are much better than those off of LO3s and LG4s.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
WHat price are they from AutoZone?
Are they new or remanufactured?
Also, i believe that 350TPI heads come with 1.94" valves which will barely clear a 305 bore, but WILL clear. the problem is in the
fact the the heads are 64cc not 58cc like your stock heads so you will lose compression unless you haev the heads milled.
That's the best I remember on this.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
