Gasket Question
Old Mar 19, 2001 | 08:34 AM
craig90formula's Avatar
Gasket Question
Replacing the intake gaskets on my 90 Formula (305 TPI) and everything is going fine, except I can't get the old baked on gasket off the heads around the exhaust crossovers. Its hard as a rock, and chemical gasket remover won't touch it. Any suggestions?
Thanks!
[This message has been edited by craig90formula (edited March 19, 2001).]
Old Mar 19, 2001 | 12:27 PM
ede's Avatar
ede
wire end bursh in a die grinder, or scotch brite pads and a die grinder
ICON Motorsports
1st & 3rd
Old Mar 19, 2001 | 01:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Anohter weapon for your arsenal would be a utility knife where the blade goes in the end of the handle instead of parallel to it, to make a "razor scraper"... Sears has this
ICON Motorsports
Old Mar 19, 2001 | 01:38 PM
85berlinetta's Avatar
I got mine off last week after they have been on there for 16 years. Just get a spot started with a paint scraper. After you get a little part of it up, you should be able to pull big chunks off. The hard part is getting it started.
Livin the hot rod dream, one day at a time.
lg4
slp muffler
pro flow air cleaner
performer intake
more to come
Old Mar 19, 2001 | 03:32 PM
Thanks guys, I will try to find scotchbrite for my die grinder. By the way, I've busted several razor blades in a gasket scraper already! This stuff is some kinda hard.
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
