96 Z24, What cleaner is recommended for the coat tbi's?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I so a can ones that said safe for coat tbi's but I don't remember what brand or where I seen it. I guess the wrong stuff will eat the coating away.Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: yep
Engine: uhuh
Transmission: sure does
When cleaning throttle bodies, if there is any question if its coated, I use simple green and a toothbrush.
This works perfect and it won't eat the coating.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Car: 86 Z28
I have a can of vavloine syn tbi and carb cleaner, it does not say if it is for the coat ones though, does anyone know if it is? thanks
Car: yep
Engine: uhuh
I wouldn't use it unless you knew FOR SURE that it won't eat the coating.
Throttle bodies will never idle correctly after a good scrub with the wrong stuff.
I had a customer come in with a surging idle and stalling on his Saleen 351 mustang, after inspection and asking him assorted questions, he admitted to cleaning it with carb cleaner. oops!!
He bought a new throttle body.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Hotrodboba400
Dec 10, 2019 07:07 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
