Installing shift light???witch wire for tach terminal?
Old May 9, 2004 | 12:49 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
it seem to be very hard to find the good wire in the dash. is it possible to plug it right to the coil??? if yes there is 4 wire witch one???
Old May 9, 2004 | 01:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It should be the white wire going to the dash from pin "D6" of connector C100 at the driver side firewall under the dash. This wire comes off the coil.
Old May 11, 2004 | 02:38 PM
FOX-GTA_89's Avatar
dont find the plug under the dash
and on the coil there is 2 white wire ans 2 red wire
but one grey plun and one black witch one???
Old May 11, 2004 | 03:14 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
The wire you want is a white wire that goes from the coil to the wiring harness. If you look you should see a grey connector attached to that white wire, thats the tach filter. The other white wire should go to the distributor.
If you wait just a minute I'll tell you if its the grey or black connector.
Old May 11, 2004 | 03:16 PM
FOX-GTA_89's Avatar
ill whait
gogogo im online
FOX-GTA_89's Avatar
but my car is tpi not tbi!!!
Old May 11, 2004 | 03:19 PM
Benm109's Avatar
Engine: 305 TBI
I couldn't get a great look at mine right now but I'm pretty sure its the grey connector.
Old May 11, 2004 | 03:23 PM
Benm109's Avatar
Engine: 305 TBI
It doesn't really matter a whole lot if its TPI or TBI (for this application). According to the wiring diagram I'm looking at for your car, its the same.
Its the white wire coming off the coil, to the wiring harness, NOT to the distributor. That's the tach signal.
Old May 11, 2004 | 06:32 PM
FOX-GTA_89's Avatar
automatical advance wire???
the white wire that goes to wirering harness is the automatical advance thats the one??? the other white wire is going to distributor???
Old May 11, 2004 | 07:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The red (pink?) & white wire in the black connector on the ignition coil goes to the distributor. The white wire in the gray connector goes to the tachometer, prior to that it splits off and goes to the Electronic Spark Control module on the drivers firewall. The red wire goes to the ignition.
Old May 11, 2004 | 07:55 PM
Benm109's Avatar
Engine: 305 TBI
Yes, it is the white wire going to the wiring harness.
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
stalkier
Aug 7, 2015 04:49 AM
drathaar907
Aug 6, 2015 04:20 PM
