what exactly are underdrive pulleys?????
Old May 9, 2004 | 11:49 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im looking into a set of underdrive pulleys but i cant seem to find out how they actually work? how can replacing one circle with another circle free up 15 hp?????????
Old May 9, 2004 | 11:59 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
An underdrive pulley, which is a different sized, smaller crank pulley, reduces the amount that the accessories spin in comparison to the crank pulley. So if its a 25% underdrive pulley it will cause the accessories to spin 25% slower, freeing up power from their drag.
A search will pull up a ton more information than I can pull off hand. It will also show problems etc that people have had, along w/ gains etc...
Old May 10, 2004 | 08:02 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ooo ok. so its basically just a different sized pulley................easy enough
Old May 10, 2004 | 10:02 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: what exactly are underdrive pulleys?????
They're a sales gimick. Nothing more.
That's just my opinion. The way I see it.... if you're driving the car on the street, why would you want to spin the water pump, the alternator, and the power steering pump SLOWER?
So your car gets hotter while sitting at a stop light?
So your alt is putting out even LESS amps than it normally does at idle while you're sitting there with your headlights and wipers on, the A/C cranked full blast, and got the stereo cranked?
So you have to put even more muscle into turning the car going through a parking lot at 1mph looking for a good spot?
All this so you can gain MAYBE 10HP at 5000 RPM???
That doesn't seem like a great way to spend ~$100.00 or more.
Old May 10, 2004 | 10:41 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool. pulleys are out!!! thanks guys
Old May 10, 2004 | 10:56 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup... good for a strip-only car, but not always entirely practical for a street car. Especially not a daily driver.
Old May 10, 2004 | 12:37 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Underdrive pulleys are good for a street car with a/c if you change the alternator pulley to the smaller one to retain the idle charging power. With the a/c compressor underdriven the head pressure stays lower at idle, the compressor cycles on and off less often, the clutch and compressor last longer, and you lose less power. The underdrive pulleys will give you somewhat better mileage and more power. I have underdrive pulleys on everything I have and like them. I don't believe that a car takes much muscle to turn anyway. I use underdrive pulleys even on my van. The power steering feels the same, just takes less tq, therefore less HP to turn. Turning a water pump a little slower won't hurt anything. It might open the thermostat a little more. Most camaros have electric fans so no problem there.
Old May 10, 2004 | 12:39 PM
ljnowell's Avatar
underdrives are wasted money for the street
Old May 10, 2004 | 12:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
