Speedometer stopped working after installing silver gauges
Old May 10, 2004 | 11:49 AM
H-BOMB's Avatar
Car: 89 GTA
89 L98 GTA
Ok, I finally decided to install my cool silver gauges and everything went well, my biggest worry was not breaking a needle but now my speedo stopped working, I checked all the fuses and they are fine. My Speedo is the only gauge that doesn't work, where do I start?
Old May 10, 2004 | 12:19 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Did you plug the speedo cable back in?
Old May 10, 2004 | 12:21 PM
H-BOMB's Avatar
Car: 89 GTA
not cable driven
Old May 10, 2004 | 12:23 PM
CaysE's Avatar
Is the overlay preventing the needle from moving? Or is it an actual speedometer that you installed?
Old May 10, 2004 | 12:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Judging by the fact that he was worried about not breaking the needle, i am thinking it is an overlay.
Did you remove the cluster for the install, or was it done with the cluster in the car still? Other than that, like CaysE said, make sure the overlay isn't preventing the needle from moving.
Old May 10, 2004 | 12:32 PM
H-BOMB's Avatar
Car: 89 GTA
they are not overlays, they are the gauges from procarparts.com. I removed all the old gauges and installed these, the only gauge that does not work is the Speedometer gauge.
Old May 10, 2004 | 12:33 PM
H-BOMB's Avatar
Car: 89 GTA
Cluster was completely removed from the car.
Old May 10, 2004 | 03:53 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
faulty gauge. Try going back to the store and replacing it.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
