Cant get car to idle to save my soul.
Old Mar 20, 2001 | 02:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i ground out iac for 30 secs pull out connector, turn car on , get it to idle at 550 turn off car, plug it back in and wham 1400 RPM idle whats gives? TB is a 52 mm IAC area is spotless. no carbon no anything. Any suggs?
Old Mar 20, 2001 | 03:02 PM
BlackBowTie's Avatar
Aren't you suppost to adjust your TPS at the same time you change your minimum air? The idle may be correct, but the TPS or the throttle stop screw may be making it go higher.
Just a thought...
Old Mar 20, 2001 | 03:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
naw did that too set it at .54 Thanks anyways.
Old Mar 21, 2001 | 06:26 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Did you check the baseline timing? Sometimes if it is too advanced it might tend to idle high.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
ZsTransAm
Aug 11, 2015 07:30 PM
