Why does my idle wander?
Old Mar 21, 2001 | 02:26 AM
Ryan89IROC's Avatar
After the car is warmed up, the idle wanders quickly from 500 to 800 rpm. Would a vacuum leak somewhere cause this? Any suggestions would be appreciated. Thanks
Old Mar 21, 2001 | 07:36 AM
tregnab's Avatar
Definately check for vacuum leaks, this is exactly what they cause. also check that the runners are tight and have a good seal, some of those bolts are tough to get to. Since you're going from 5-800 rpm, I would suspect a small leak, maybe one of the smaller outlets like the ignition advance or cruise control. If you suspect a line, take it off and cap the inlet to see if the idle is smoother.
Old Mar 21, 2001 | 10:35 AM
Steve89GTA's Avatar
Check that IAC motor, mine has loose to the touch when I checked it and had a shaky idle.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
