Fortify the frame from twist... how?
Old Mar 21, 2001 | 01:15 AM
[-sLaYeR-]'s Avatar
I am trying to decided weather I should go for the Iroc with T-Tops, the convertable, or the 1LE. I like the 1LE's options, but I like being able to take the roof off. Is it possible to make the frame strong enough so that I doesn't twist and screw up you seals for the roof? If so, how, and about how much torque can you have b4 you sould worry?
Any info would be a lot of help.
Jay
'91 RS 305 5.0L V8
All stock for now...
Old Mar 21, 2001 | 09:24 AM
Superblue87Formula's Avatar
all third (and 4th) gen cars deserve subframe connectors, even the v6's. It will stiffen up the frame immensely
Old Mar 21, 2001 | 11:10 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
any t-top or vert car should have sub-frame connectors.if possible get the weld in type.the bolt in type of sub-frame connector are just as good as the weld in but the bolt in will elongate the bolt hole and render the S/C'S almost usless.if you do get the bolt in's have them welded in.
1991 banditt2 #130 of 600
Project 350 TPI Banditt2
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
PurelyPMD
May 5, 2016 04:57 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
