Only .011 inch clearance!!!
Old Mar 21, 2001 | 06:09 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Is .011 inch too little for the clearance between my rod bolts and my block pan rails on my 383?
Also I was using lipstick to check where there was interference in my oil pan...how exact should I be with getting it all off, isn't lipstick petroleum based anyway??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old Mar 21, 2001 | 06:22 PM
ede's Avatar
ede
i was thinking .020 was about the least you could run, but i'm not sure. i'd use brake cleaner on a rag to remove the lip stick.
ICON Motorsports
1st & 3rd
Old Mar 21, 2001 | 06:37 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I would say that's too close..I would shoot for .050
Old Mar 21, 2001 | 09:22 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I agree with TPI406..shoot for at least .050,but .060 would be the usual clearance on a stroker.You have to be especially careful if you are running forged steel rods you should be fine at .050, anything less would be cutting it too close.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
