Rod Length??? 5.7 or 6
Old May 16, 2004 | 03:34 PM
  #51
dave89gta's Avatar
Originally posted by Joshua
If we were to use a 5.7 inch rod and 3.484 stroke as our example you would see that no matter the RPM the distance traveled between let's say 2 degrees to 5 degrees would always be the same. You also know that if the RPM is constant then it takes the same amount of time to travel from 2 to 5 degrees as it would take to travel from 5 to 8 degrees. At higher RPMs the amount of time to travel 1 degree would lessen but being in our case that it's constant it would always be the same amount of time for every degree.
This isnt true. This can be seen easily at TDC or BDC. When the crank position is 4* past TDC, the piston has moved 0.005531" down the bore from its position at 0* (TDC). However, at 94* (the same 4* past the 90 position), the piston moves 0.12138" from the 90* position. The piston does not move the same amount for each degree of rotation of the crank.
These calcs were made using a 3.48" stroke, and a TI-83 calculator.
Old May 16, 2004 | 03:47 PM
  #52
Joshua's Avatar
I'm saying that the distance between 2 - 5 degrees is the same whether you're traveling at 2000 or 5000 RPM. Yes it is different than the distance between 5 - 8 degrees but my point was that the same goes for 5 - 8 meaning that at ANY RPM the distance traveled between 5-8 or whatever is going to be the same. It's not dependent on RPM.
Edit:
Also in that quote I mentioned time being the same. So in your example while the distances are different the elapsed time is the same. Meaning the latter has a higher velocity.
Old May 16, 2004 | 05:21 PM
  #53
dave89gta's Avatar
I misunderstood you. You are exactly correct. :hail: :hail:
--Dave
Old May 8, 2006 | 11:35 PM
  #54
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok that guy is just another story but thank you I have reading material at work tomorrow while I listen to people talk about how they want their rewards credit card to give them non-stope flights from manchester to portland oregon. or why do I have to take such a small plane from marthas vinyard. I know they have larger jets out of there. or why is it so much money to fly from white plains to london. I know if I flew out of jfk I could do so for so much less. "well ma'am you could fly out of jfk and save that much money" but I don't want to it's too much hassle and they are so close to each other can't you just give it to me for that price instead?
Old May 8, 2006 | 11:52 PM
  #55
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Ahhh!!! I wanted it to stay in obscurity!!! You rotary people!! Harumph!
Ed1LE
Sep 30, 2018 09:14 AM
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
usafirebird
Sep 29, 2015 11:58 PM
