Firing on all 8?
Old Mar 21, 2001 | 11:55 AM
Steve89GTA's Avatar
Firing on all 8?
I had a wire burn up on my exhaust a while back. Looks ok and it shows 0 ohms on my DMM but the outter skin has burned off completely...I'd like to know if the idle should change slightly if I pull a plug wire while the engine is running, I'm not sure my motor is running on all eight.
If I pull a plug wire, I should hear a difference in the tone correct?
Steve
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 21, 2001 | 11:58 AM
Bort62's Avatar
try it, You will notice in a big way
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 21, 2001 | 06:30 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Don't I know it! Went to see why I had some drivability problems the other day and went to change the timing...grabbed the dist and found out the #4 boot was loose the hard way - ZAP! It's really quite a rush. Seriously if you have a loose wire you'll know something's really wrong.
Old Mar 22, 2001 | 02:15 AM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
Hey, if one of your wires falls off the plug, don't try putting it back on the plug with the engine running like I did while I was hanging on to the fender.........ZAPP!!!
My hat flew off when my head hit the hood and got eaten by the fan!!!
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
