What are the biggest valves you can run on a 383?
Old Mar 21, 2001 | 01:06 AM
Dan87IROC-Z's Avatar
What are the biggest valves you can run on a 383, I am sure that you can go larger than 2.02"/1.60", but how much larger?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 21, 2001 | 11:51 AM
Polecat's Avatar
You can run up to 2.05's on heads like the Dart Iron Eagle 215cc.............good heads.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Mar 21, 2001 | 06:33 PM
ede's Avatar
ede
maybe 2.1 and 1.6, if you're after more flow you can run manley pro flows without having to go to a larger valve
ICON Motorsports
1st & 3rd
Old Mar 21, 2001 | 07:14 PM
Bort62's Avatar
Drill holes in your valves, it helps them Flow better
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 22, 2001 | 08:36 AM
Mark W. Winning's Avatar
I am running 2.08's on my 383. I believe they could even go larger, but on the street, it is not as worth while. With a bigger valve and an even bigger cam, you can get much better breathing, but then trying to run a single 3" exhaust puts a cork in it.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
RazorN8
Jan 7, 2022 11:44 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
