383 Flywheel
Old May 14, 2004 | 01:03 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
383 Flywheel
My stroker should be ready to drop in tomorrow but...I may have overlooked one thing. Am I going to need a new 400sbc flywheel or is there a way to make the old one work?
Old May 14, 2004 | 05:44 AM
ede's Avatar
ede
your choice of flywheel depends on how the engine is balanced.
Old May 14, 2004 | 07:56 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I have a 400 balancer but the machine shop already balanced it. Would have they needed a flywheel to do so?
Old May 14, 2004 | 08:03 AM
ede's Avatar
ede
are you internal or external balance
Old May 14, 2004 | 08:08 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I am pretty sure that the crank must be externally balanced if I needed a 400 balancer right?
Old May 14, 2004 | 08:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The shop would not have needed a flywheel. They would most likely either neutral-bance it, if it was an internal balance seup; or balanced it to the stock 400 spec, if it was external balance.
It could be either; there's no way for us out here to know which parts you have.
Ask your machine shop what they did, and which flywheel to use; either a 400 flywheel, or an everything else flywheel. If they tell you that you need the "everything else" (neutral balance) kind, then you have the wrong crank damper.
Old May 14, 2004 | 09:17 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
With the 400 balancer, you definately need an external balance 153 tooth flexplate. I have one if you're interested.
email me for more info.
www.geocities.com/dzperf
Old May 14, 2004 | 09:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Problem is, he says his machine shop "balanced" his motor; and he says he "has" a 400 balancer; but we don't know if those 2 things have anything to do with each other.
The one piece of the puzzle that is required here is to know whether the motor is internally or externally balanced. As we all know, a 383 can easily be built either way, and given what he posted about his particular motor, there's no way to even guess which one he has.
The machine shop should know which version he has.
I'd strongly advise that he find out what his motor really is before he starts going out and buying parts that may or may not be the right thing.
Old May 14, 2004 | 10:07 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Not to muddy the information further but..., if he has a one piece rear seal engine then the flywheel he buys will have a weight on it and should have went the the parts to be balanced.
There are several ways they may have done it though.
If it's a one piece and they neutral balanced it he will need to removed the weight and get the flywheel balanced.
If it's a two piece rear seal crank it could have either been balanced for internal or external balancing. But, if it's been internal balanced he wouldn't need a 400 balancer.
There's really no way of knowing what he needs without more information.
FYI, mine is a one piece rear seal crank, with a 400 balancer and the newer 3" bolt hole weighted flywheel. Odd combination, but correct and it was all balanced together.
Why do I have a feeling we're going to be reading a post soon about, VIBRATION in a new engine?
Old May 14, 2004 | 12:57 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
OK guys thanks for the replies. Turns out the flywheel is balanced already with a new weight. The crank is externally balanced.
LT1Formula
Oct 8, 2015 08:34 PM
mfp189
Sep 27, 2015 09:25 AM
