Power steering pump cooler
Old Mar 21, 2001 | 10:44 AM
Steve89GTA's Avatar
Where can I get one of these!
I found a tranny cooler, can i use this? or are those lines under some serious pressure.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 21, 2001 | 05:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The return line (the one with the hose clamps) has very little pressure, you could put one there. The factory put one on alot of these cars; it's a piece of tubing that loops across the car below the radiator. Very simple, better than nothing I guess.
ICON Motorsports
Old Mar 21, 2001 | 06:05 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Is that what that b@stard piece of tubing is!? I was just pondering over that thing the other day, wondering why GM would have done such a thing. Now I know..Thanks RB!
Old Mar 21, 2001 | 10:15 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I snagged that loop of tubing along with the bottom fan mounting bracket from the car I got the fan setup from. I just wonder how much it helps, and if it is even needed.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Mar 22, 2001 | 11:27 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That factory p/s cooler wasn't on my '84 parts car, but it's on my '86, if that helps determine the year of change...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 22, 2001 | 11:58 AM
gruveb's Avatar
Car: 1989 IROC-1
Tom P,
My 84 Z has a power steering pump cooler!!!
So, maybe it was an option for a package or something like that?
Old Mar 22, 2001 | 12:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My 83 has it.
ICON Motorsports
Old Mar 22, 2001 | 01:50 PM
Steve89GTA's Avatar
I wonder why newer model thirdgens don't have this tubing...well, not that I've seen that's for sure
Old Mar 22, 2001 | 05:47 PM
Jason M 91Z's Avatar
Mine has it. Doesn't look like it'd cool much of anything though. How hot does PS fluid get anyway? Maybe on a race car revving over 4K alot, but on a street car? It might be something they did with cars with optional tires (235's/245's) because of the increased turning effort required, and the soccer moms who stop all the way to turn the wheels lock to lock.
-Jason M. 1991 Camaro Z28
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
toronto formula
Nov 10, 2015 06:17 AM
backtothe80s
Sep 5, 2015 12:39 AM
TreDeClaw
Aug 14, 2015 06:58 PM
