How do you know if your balancer is bad? Is a 6 3/4 alright on a 350?
Old Mar 22, 2001 | 06:59 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
The balancer was only a month old when I brought it but know that I am thinking about it how do I know they did not use a hammer to get it off? What the sighnes, iti s a oem replacment one from summit, it look like it was in good shape whenI looked at it, is the size okay for a 350 that does not go over 5,000 rpm? Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Mar 22, 2001 | 06:39 PM
ede's Avatar
ede
if you got it from summit it's new. if you bought it used and someone used a hammer there would be hammer marks on it. if you're thinking the outter ring has moved only thing i can think of is to use a degree type timing light and see where the marks fall.
ICON Motorsports
1st & 3rd
theshackle
Sep 17, 2020 08:26 AM
Linson
Aug 31, 2015 04:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
