8 pounds of vac pull?
Old Mar 22, 2001 | 07:06 PM
gruveb's Avatar
Car: 1989 IROC-1
Is between 6 and 8 pounds of vac pull acceptable? I have about 7 to 6 at the carb and 8 at the intake manifold.
I've got an L69, right now running an edelbrock 1406, Weiand action plus intake and a comp cams 12-238-2. Idle is at about 1000 to 900 and timing is set at a conservative 6* for now.
Is this about right?
Old Mar 22, 2001 | 10:02 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I've no idea of the cam grind, but no...that's waayyyy too low for any streetable motor.
Did you just install the cam, or anything else? Could be vacuum leak, severly mistimed motor, swapped plug wires, etc.
Old Mar 22, 2001 | 10:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Another thing, you maight have the throttle blades opened too far, to compensate for an adjustment/idle problem...but even so, I'd still expect to see more idle vacuum.
pjsparts
Oct 29, 2025 06:39 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
sylentnite
Sep 9, 2015 02:55 PM
rjcme
Sep 5, 2015 01:23 PM
tgp1990
Sep 4, 2015 06:24 AM
