Chipped fuel injector nozzle, do I need to replace it?
Old May 15, 2004 | 08:48 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I have 3 damaged injectors I found while replacing my intake manifold gasket. 1 I am shure I need to replace. The tip of it looks like the bottom picture, it is cracked and the nozzle is loose. The other two injector nozzles have chips missing from them. They look like the top picture, the chip in the picture is to scale. The injector o-rings are ok and the injectors did not leak when I took them off, im sure i didnt damage them when I removed them, (I was carefull). Do i need to replace the chiped injectors? Will they be ok to use since they dont leak? I dont want to buy them If i dont need to, Thanks
Attached Thumbnails Chipped fuel injector nozzle, do I need to replace it?-chip.jpg
Old May 15, 2004 | 08:58 PM
88fbird's Avatar
Car: 84 S-10:(
I don't think the chip will affect the performance. But the one that has the loose nozzle should be replaced. You might be to get a whole used set, clean them and replace the bad ones. I got a good set of used one in the classified section here for $20. Then put them in F/I cleaner for a while, Replaced the o-rings and installed them. They work great.
FBird
Old May 15, 2004 | 09:05 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I am going to put it back together this week, so I will probably just buy one new one tomorrow. I thought about soaking them. I was wondering if it would be safe to let the tips sit in carburator cleaner for a while, or should I use fuel injector cleaner. Im sure I should take the O-rings off first.
Old May 15, 2004 | 09:12 PM
88fbird's Avatar
Car: 84 S-10:(
Here's what I did.
Take the o-rings off
Put them in a shallow pan
put them in pairs.
Tilt them together, where the electrical connectors go, so it doesn't get into the solvent.
then put the cleaner in the pan until it covers the nozzels. Let them soak for a while, then shake them out.
Put on some new O-rings with some Vasaline, and reinstall.
It worked for me and a couple other guys I know.
FBird
bryan623
Mar 22, 2021 06:43 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
