Oil Guage Reads ZERO???
Old May 16, 2004 | 09:51 AM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
Sitting at red light the other day and relized my oil guage was flickeing around zero or the red zone. I reved it up and it went up would max out at 30 when it would go near 50-60 before when i'd rev. Got home, checked oil level it it was FINE
what am I looking at here?
oil pump?
oil guage?
thanks
Old May 16, 2004 | 10:10 AM
Beefy89's Avatar
Always suspect the gauge first..
Old May 16, 2004 | 10:28 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Does it sound or run any different than before? You can pull the valve cover and see very quickly when you fire it up if you have oil pressure. If it is zero at idle, there will be no oil flow at the rockers. The engine usually will sound unhappy, too.
Here's a novel tip. If you don't have oil pressure showing, don't assume it is the gauge and drive the car around. Find out for sure.
Troy
So Cal
Old May 16, 2004 | 12:00 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
go buy or borrow a mechanical gauge and hook it up on the engine and that will identify if its the gauge ...thats what i would do first then go from there
Old May 16, 2004 | 02:08 PM
Engine: 305 TBI
The engine sounds fine. No weird sounds or anything obvious atleast.
Another thing is that it only seems to have this problem after it warms up a bit. from a cold start oil pressure is fine,,, well i should say that the guage reads fine.
.... Just checked the valve covers (looking through the oil cap hole), and when the engine is running I can see a small trickle flowing through but no more than that, even when I rev it.
Is this normal?, I would think that it should of been spraying everywhere when I took that cap off.
Old May 17, 2004 | 01:30 PM
Engine: 305 TBI
well i got to my oil pressure sender right abouve my oil filter, and im pretty sure this is causing my problem. when i pulled the clip of it a few drips of oil came out which seemed strange,. dried it off and put it back, still reads low oil pressure. so i guess need a new sender unit.
the main piece spins around but wont unscrew, is this normal?
and if i unscrew the bolt it should come off right?
and is oil gonna pure all over me when this thing DOES come off?
Old May 17, 2004 | 01:36 PM
Mike92RS's Avatar
Yeah when I replaced mine the main body would spin around. You can get a special socket that should fit around it. Mine failed high though (gauge was maxed out, not bottomed out).
Old May 17, 2004 | 07:02 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Originally posted by 91CamaroDude
T
Id say you have more problems than the sender. when you have the cover off and rev the motor you should get a mess of oil, not a trickle.
Old Oct 21, 2004 | 09:31 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
my motor does this too...brand new, no smoke at start up (when cold or warm) fires right up no problem with a press of the pedal once and the turn of the key (when cold) when warm it takes a couple cranks to start up....which I thought was kinda wierd.
regardless, no smoke, no horrible sounds, cept my lifters sound a bit louder....im scared!
Old Oct 21, 2004 | 11:11 PM
philapino18's Avatar
Car: 88 Camaro
Engine: 305 TBI
My car was doing the exact same thing, it would go to zero, after check to make sure that i had oil, I replaced the sending unit, and that solved the problem. Good Luck.
Old Oct 21, 2004 | 11:15 PM
x_wolf's Avatar
Car: 91 Camaro RS
thats next on my list...I HOPE TO *** the kinda ticking I hear is just my exhaust leak and its gotten worse, and not a lack of oil to my top end.....
I HOPE TO ***! that changing the sender (which leaks btw, I just went to look at it....had oil all over the plug) will fix this problem, and while I'm at it, might as well jack the car up and look for other leaks
lol
PRAY FOR IT!!
Old Oct 22, 2004 | 01:09 AM
sellmanb's Avatar
Car: '86 Berlinetta
like mentioned above, before you go buying a new sending unit (because your NEW sending unit could end up being bad as well, you never know)... go buy a MECHANICAL gauge and read that, then you'll know for sure what your oil pressure is, and if your oil pressure sending unit is going bad.
Not to scare you, but the same exact thing happened to me when I spun some bearings, I'd read about the same oil pressure 0 at idle, 30 top with revs.
Old Oct 22, 2004 | 01:14 AM
x_wolf's Avatar
Car: 91 Camaro RS
well I would IMAGINE that if I did in fact spin a bearing (which would be hard considering I baby this thing) then wouldn't the engine make some noise in the bottom end?
Old Oct 22, 2004 | 09:29 PM
sellmanb's Avatar
Car: '86 Berlinetta
yes, it would knock... I believe the way it goes is a rod bearing will knock at low RPM, a spun main will knock faster as the RPMs raise.
Old Oct 22, 2004 | 09:31 PM
sellmanb's Avatar
Car: '86 Berlinetta
either way, get a mechanical gauge, you can use it again for friends cars, beaters.... it's better to be safe than sorry, no? You could have some bad bearing clearances too that cause it, you never know.
Old Oct 23, 2004 | 02:21 AM
x_wolf's Avatar
Car: 91 Camaro RS
MWAHAHAH JUST A GUAGE!!! MWAGHAHAHA....and my valve covers were leakin a lil bit causin my oil leaks....SO out goes my sending unit, in goes a plug!
cheers and thanks
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
