A/C problem
Old May 16, 2004 | 01:35 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
A/C problem
I was working on my car most of the day yesterday, and while I was trying to set my timing on it, (I forgot to turn of the A/C) my A/C compressor started venting freon out of a pressure relief valve on the back of it, so I got a new compressor and accumulator and filter (required to keep the warrantee valid) changed them all out, put 2 -4oz. bottles (tech manual at autozone says 6-8 oz. for 134A converted system) turned the A/C on and tried to fill it, and it only took 2 1/2 12oz cans of freon, before the gauge was going into the yellow and then about 30 seconds later the combressor started out the vent again...WTF, by the way it still blows cool from the vents, the mechanic who converted it and my dad told me if I change thing out quickly I don't have to worrie about vacume the system so I diden't. any suggestions. thanks in advance
SrA Mark D Lewandowski, USAF
Old May 16, 2004 | 01:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds to me like it has moisture in it, which was freezing in the orifice tube and creating a blockage, which made the head pressure go REAL high and exceed the high-pressure vent valve's setting.
This is assuming that your cooling fan was working: a non-working fan will allow the temp and therefore the pressure inside the system to go sky-high, and have the same effet of creating excessive head pressure.
Old May 16, 2004 | 01:48 PM
Engine: 383
So should I get it vacumed to remove the moisture?
Old May 16, 2004 | 02:10 PM
nascarfool.com's Avatar
Yes you should use a vacuum pump on the system when it has been opened. An a/c filter/drier absorbs moisture pretty fast when opened to outside air.
Old May 16, 2004 | 02:17 PM
Engine: 383
thanks for the responces, I'm going to head off to the bace garage in about 5 minuts and get them to vacume it out
my86bird
Oct 23, 2015 12:20 PM
greenyone
Sep 2, 2015 03:39 PM
greenyone
Aug 29, 2015 11:08 AM
BikeFarm
Aug 11, 2015 11:35 PM
