153 tooth too small!
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
Hi guys, this question may have been answered already but i didn't find the answer when i did the search. I have a 5.7 engine.
I'm not sure what flywheel came with the engine.The 153 tooth or the 168, i had the engine rebuilt. the mechanic gave me a new
flywheel for the engine,it's a 153 tooth. i bought a new mini starter for it. the flywheel does'nt come in contact with the new starter.So i think that i need the 168. I thought the 168 was only for big blocks. am i wrong?
First off manual trans cars have Flywheels... and on an automatic it is referred to as a flex plate. Assuming you have an automatic... you would require a 153 tooth flexplate. I would say that you have the wrong starter... as opposed to the wrong flywheel.
Engine: 5.7L TPI
Thanks Johnyiroc,
I've always wondered what was the difference in a flywheel
and a flex plate. So i have the wrong starter huh? (thats a bummer)I paid a 100 bucks for that starter! The 153 tooth flex
plate comes up short about an inch, so going to a 168 tooth won't
solve my problem? I would hate to have to buy another mini starter. although i'm just now installing the starter I bought it over a year ago. I don't think the guy i bought it from will exchange it for me.But i'll ask. I saw some flex plates in the JEGS
catalog, some were only 68 dollars or so. Others were close to 200 dollars. What's the difference?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Get a 168 tooth and put it together. The difference with the flexpaltes is more than likely one is a stock replacement and the others are SFI approved. THe SFI units usually have thicker material for the center peice and have more welds to keep the tooth ring attached to the center.
Imagine using a transbrake set at 4K and releasing all that energy into a stock flexplate...shatter city.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by ljnowell
Not necessarily. If he has an older style engine, like a 2 pc rms, it will require a 168 tooth flexplate.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
nothing will **** you off quicker than leaning in to hit the key for the first time on a new engine, and hearing it spin free. Ahhh.
since you're supposed to check the gear pattern and all before you try to start it.
plus its off by about a inch, how could you NOT notice?
Car: 4
Engine: 6
Transmission: 5
I'd recommend getting the right starter for the smaller flex plate that you now have; and sell the starter you have. Should bring most of that $100 back to you. This time, get one of the starters that has the bolt holes for both mounting locations. The smaller flex plate will mount the starter that much closer to the center of the motor, leaving more clearance to headers.
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Summit has one made by powermaster that will work and it has a nose cone instead of the race type exposed. It is on order hope that it works. For $200 I only get a 1 year warranty. The auto value brand was 150 and 10 year warranty, but it was the wrong one.
Depends on what bolts up. on my engine you cant bolt the starter for the 153 tooth flexplate, because it is too old, doesnt have the right hole. He needs to check before he buys anything. Find out which starter bolts up and then get the new flexplate to match.
Car: 4
Engine: 6
Transmission: 5
Car: 91 Camaro Vert
You're right, that should never happen. But being a smart-*** on the internet isnt gonna change anything.
to keep from tearing up your engines ring gear, especially with a aftermarket starter, you need to check how the gears mesh.
and i disagree on your second point. being a smartass on the internet amuses me. me being amused releases more endorphins to my brain, making me happier. me being in a good lets me work on my car better.
so you see, im only being a smartass to you to help me work on my car. its for the good of a thirdgen. therefore, relevant to the site.
:lala:
well yes being a smart *** is a very fun way of making yourself feel better but it can also make you look like a total *** instead of a smart ***..LOL.....
Engine: 5.7L TPI
153 tooth too small
What's up guys,
man, i didn't know that there was so many responses to my question. I posted this question some time ago back in May i believe. thanks for all of your replys.
even though the engine is still not in the car, here's what i did.
I ordered a 168 tooth FLEX PLATE from JEGS. Turns out that i ordered the wrong one,(got the one for a 400 engine) so i sent it back and got the one for a small block 350. I installed it on the engine, and it looks like it's gonna work perfectly.
I just bought a used 700r4 tranny for it. So maybe i'll finnally have this car running soon.
(by the way, if anyone need a 153 tooth flex plate i have one for cheap) thanks again, Big John
Car: 91 Camaro Vert
dumb ***
jack ***
or just plain ***.
at one point in time ive been accused of them all.
i really dont worry too much about it, i kinda follow the words of what a Eleanor Roosevelt once said:
Nobody can make you feel inferior without your permission. --Eleanor Roosevelt
Originally posted by MrDude_1
smart ***
dumb ***
jack ***
or just plain ***.
smart ***
dumb ***
jack ***
or just plain ***.
codeysabatini
Nov 10, 2015 04:07 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
dimented24x7
Sep 17, 2015 06:58 AM
