Ticking I hear TICKING
Old Mar 19, 2001 | 04:17 PM
Spyder's Avatar
For what ever random reason, now and then, there is a itermintant tick. Here and there, now and then with no rhyme or reason. Any ideas? Its in a 82, LG4
Old Mar 19, 2001 | 05:04 PM
Aaron87SC's Avatar
Check your oil lately?
Old Mar 19, 2001 | 05:22 PM
bleak's Avatar
yeah, check your oil. LOL.
Old Mar 20, 2001 | 02:04 PM
Spyder's Avatar
Yes I have, it was fine. Its now and then not like low oil, I know what that sounds like. I mean really what may it be?
Old Mar 20, 2001 | 02:05 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
COULD... be rockers
Hecubus
http://www.tweak3d.net/temp/z28.jpg
91-Z28 305 Tpi "G92" mods-- K$N/Foil/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel & Oil Press Guage's
Old Mar 20, 2001 | 02:39 PM
Spyder's Avatar
Hummmm, idea, now how would I go about trying to figure that out for sure.
Old Mar 20, 2001 | 02:51 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
I've "herd" of people doing this
but, taking a peice of hose maby 2 feet long and putting one end to your ear and probing with the oter end to locate the sound
will it tick in idle or just under a lot of load or compleatly random?
otherwise taking the valve covers off is the only other solution to make shure
Hecubus
[This message has been edited by Hecubus (edited March 20, 2001).]
Old Mar 20, 2001 | 02:55 PM
superz's Avatar
it is probbly your lifters. they are hangin up a little. how many miles is on it?
Old Mar 20, 2001 | 02:59 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
What ever it is I'll bet it's something in the valve train
Hecubus
Old Mar 20, 2001 | 03:07 PM
Spyder's Avatar
It will mostly do it a idel. Usually not right when I start it up though. I notice it more after it has been running for a while. I have had some people mention that it <u>might be</u> be a relay of some form. Then again, motor has 156k on it. I have a ZZ4 but its not ready to go in.
Old Mar 20, 2001 | 03:11 PM
Spyder's Avatar
Any "top secerate formula" you guys would recomend to maybe make her quite down a little? Its not loud just pissing me off. Another thing like I sad, they are random and have no rhyme or reason.
Old Mar 21, 2001 | 06:13 AM
custman87T/A's Avatar
Are you sure its not the PCV clicking?
Old Mar 21, 2001 | 07:28 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Or the mixture control solnoid in the carb going out?
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 21, 2001 | 07:46 AM
tregnab's Avatar
Here's a cool trick. count how many ticks you hear a second. Assuming your idle is around 700, if the tick is in the valve train it will tick about 5 times a second. (camshaft runs 1/2 of engine speed) If this is true, use a broomstick and set one end on the engine mount, the other end on your ear. Check both mounts. If it's the valve train you'll only hear the tick on one side, and you can probably try adjusting the rocker arms at this point.
Old Mar 21, 2001 | 11:07 AM
greearhr's Avatar
Run! It's a bomb!
Old Mar 21, 2001 | 02:00 PM
Spyder's Avatar
I don't think that it is the PCV valve but I will check that tonight. It is only 1-2 a second at most. Idel is around 500. Now if it is the mixture control (which I have been having problems with) then I guess that means that a new carb and distro go on hu?
Old Mar 21, 2001 | 02:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
((choking on my coffee because of Greearhr))
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 21, 2001 | 02:17 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
It may be an exhaust leak. I've got one right now that does the same thing. It ticks once or twice a second every once in a while.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Old Mar 21, 2001 | 02:25 PM
superz's Avatar
if it was exhaust it would make noise all the time, you said it doens't do it till it is warm, so that rules out valve train, without actually hearing it, i have no idea
Old Mar 21, 2001 | 02:26 PM
Spyder's Avatar
Some one else mentioned that on another board, that might be the case, once I can get it back under a hoist I will be good. I just wanna get this to sound normal. I have two or three other problem with
1. I only have three out of the four gears (auto)
2. I was told the strut plates are bad, heres the problem I don't know what they are. I have been around cars for some time, I have heard it before but never quite understood what they are.
3.Clicking in the front passanger side in the front hub. If I apply slight breaks it will go away. Breaks are good, I assume that its the wheel bearing.
If you guys have any ideas on any of these that would be great.
Old Mar 21, 2001 | 03:50 PM
greearhr's Avatar
If you have tranny problems I would suspect it as the source of the noise. Have you tried sticking your head underneath the door while it's running? If it's louder suspect tranny or exhuast leak.
Bear Tracks
Old Mar 22, 2001 | 04:30 AM
rhawki's Avatar
I've heard AIR pumps make a ticking noise before. I also had what i thought was a valvetrain tick at one time, turned out to be a cracked flexplate, and normally you'll only hear that at idle.
Does it sound like it's coming from underneath the car or from the top?
-Rich
Old Mar 22, 2001 | 12:08 PM
theformula's Avatar
lol greearhr
Old Mar 22, 2001 | 01:00 PM
Spyder's Avatar
I FOUND THE TICKING! It was right next to the ERG. It was a wiring harness that had three air tubes going out of it. Not sure what they are for but it looks like it is for the SMOG/AIR stuff. Too bad the belts and half of the hoses are not hooked up. That was actually my problem. One was cracked and leaking. For some odd reason if it had the leak it would tick and when I plugged it, it stopped. Sorry about the non-technical knowing of what it is but I really don't know. Too many things under the hood of the computer carb cars.
The whole thing with the tranny is kinda funny. I was told it had a 700R4, well when I looked its a Turbo 350 or 400 (yes I don't know which) so that just leaves the strut plates.. Thanks much guys for all your help!!
Old Mar 22, 2001 | 01:12 PM
Bort62's Avatar
ROTFL, that would explain only 3 gears!
Did they leave the stock Shifter, whoever swapped it in then ?
what year car is it, you sure its not a 200C?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 22, 2001 | 01:49 PM
Spyder's Avatar
Its an 82, the stock shifter is still in the car. When we threw it up on the lift my auto teacher told me it looks like a turbo when I asked him. Once I saw it I realized that it was not a 700R4. Would 2,500 RPM sound right at 55 or what rear end would I have then? Its not the 3.08 I assume becuase that seems way low. I could say like a 3.73 might sound right.
Old Mar 22, 2001 | 01:54 PM
84TransAm's Avatar
wow, you had soo many suggestions. And all of them wrong!
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Mar 23, 2001 | 02:03 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
I have that problem, Ive narrowed it down to the Odometer clicking
1985 Z-28, tpi, basically stock......so far
SEE YOU LATER INTIMADATOR
R.I.P. #3
Falcon50
Aug 22, 2020 03:26 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
