Serious engine problem..HELP
Old Mar 23, 2001 | 01:00 AM
ADMZ24's Avatar
Car: 1991 Trans Am
My car has been starting horrible. It takes almost five or six seconds of cranking to get it going. It had been getting worse. Now, just the last few days, it has developed a tick, kinda loud. At idle, it is audible, but at just above idle it is loud. tick, tick, tick, sounds like a timebomb!! I dont hear it when I take off, but when I lift off the gas, I can hear it again. What is it????? Also, I have noticed smoke from the exhaust on startup, and sometimes, a funny smell. What is wrong?? Car has 154,500 miles. Is the engine on a downhill slide, or is thsi an easy fix....I guess it would help if I knew what is wrong . But I am hoping you guys will help me there!!!! Any suggestions are welcome..
1991 WS6 Trans Am
Medium Green Metallic
Beechwood interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
Old Mar 23, 2001 | 02:17 PM
ADMZ24's Avatar
Car: 1991 Trans Am
PLEASE!?!?!
ANYONE!!?!?!?!!
Old Mar 23, 2001 | 02:31 PM
Spyder's Avatar
Humm check for Ticking, I hear TICKING just down a little ways, alot of good posts were in that about some of the same issues.
Old Mar 23, 2001 | 03:17 PM
Blade's Avatar
That ticking sounds like a exhaust manifold gasket is bad. If you have the stock manifolds, you wont have gaskets, but it sounds like the time to put a set on.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
