can't get the timing correct
Old May 17, 2004 | 08:21 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
Help!! I've just put together a 5.7 with a crane cam 280H series, actually a blue racer cam wg-1159, and I can't get the car to start or even to fire! I've checked the timing chain, timing marks, distributor, valve adjustments, everything that I can think of, can anyone help?
thanks
dale
Old May 17, 2004 | 09:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you make sure that your were on #1 TDC for compression stroke and not exhaust? When the rotor is pointing to the #1 plug wire make sure you are at TDC for #1 and the timing tabs on the timing gear are both at 12 oclock. If one is at 6 and the other is at 12 (meaning you are dot to dot) you are at the firing for #6.
Old May 17, 2004 | 09:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Flip the distributor around 180° and try again.
Old May 17, 2004 | 09:55 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i did that and a weird noise came from my motor. it was like VROOM VROOM. i guess i did something right
Old May 17, 2004 | 09:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yes, theres a certain magic that lies in the number 180.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Linson
Aug 21, 2015 02:12 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
