Adjustment after broken stud
Old May 18, 2004 | 09:48 AM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
I broke one of the rocker arm studs on my #7 cylinder. I've replaced the stud and two push rods, the rocker arms are OK. Is there any special procedure I need to go through to adjust these two valves other than cranking the engine without the valve cover on and going from there?
Old May 18, 2004 | 09:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's about it; pre-lube everything with white lithium, especially the rocker ball, but also the valve stem tip, and the push rod ends. Put the rocker nuts on almost as far as all the rest, start it up, and adjust in the noraml way.
Old May 18, 2004 | 10:43 AM
pigsticker's Avatar
Car: 1992 z28
Thanks for the info RB.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Eric-86sc
Exterior Parts for Sale
Nov 16, 2015 10:20 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
