Edelbrock headers very close to frame
Old Mar 23, 2001 | 03:15 PM
tregnab's Avatar
I have the Edelbrock tubular exhaust headers, and the driver side header has always been about 1/16" away from the frame member down there. Under mild acceleration, it rattles a bit.
It's never been a problem, I was just curious if other members have noticed this. Maybe I could have a muffler shop barely bend it or something.
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
Old Mar 23, 2001 | 05:06 PM
Blade's Avatar
Mine has plenty of clearance. Maybe you frame is twisted a bit.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 23, 2001 | 05:26 PM
87firebird's Avatar
Your frame might be a little bent
Old Mar 23, 2001 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You may need new motor mounts.
ICON Motorsports
Old Mar 23, 2001 | 10:53 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I've got Edelbrock headers, and I had a real problem with this. Every time I'd start the car up, grrrrrr. And everytime I'd accellerate, GGGRRRRRR. Talk about embarassing. It took me forever to get it right! I had a problem with the flanges on both headers hitting the frame. I fixed this by cutting off a little bit of one of the flanges, and turning them to just the right angle so they wouldn't rub. I also had a problem with the y-pipe rubbing against the oil pan and the crossmember. I fixed this by taking a prybar to the y-pipe. All I can say is good luck.
Old Mar 24, 2001 | 07:45 AM
tregnab's Avatar
My frame is chillin, there's no funny business there. My problem is as ViciousZ described, low clearance right at the flange. At least mine is only on the driver side. Thanks for the input, I'm just glad to hear someone else had the problem.
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
Old Mar 24, 2001 | 09:02 AM
shawn87gta's Avatar
Mine do the same thing - it's so annoying. They are within ~1/16" of the frame in a couple of places. They WILL be "adjusted" for better fit when I have them off.
Old Mar 24, 2001 | 01:10 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Mine do the same thing. When the car was stock it didn't do it, but now with the Dart Pro 1 heads they sit a little higher (raised exhaust ports). If I don't have the the flanges set exactly right it makes the whole exhaust rattle.
Sparks a flyin'.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
Ducati900ss
Sep 2, 2015 09:05 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Zeek1041
Aug 21, 2015 08:45 PM
