Someone freakin Stole my Engine Harness!!!!!!!
Old Mar 19, 2001 | 10:37 AM
vortech305's Avatar
This goes to show how some people can be real *******s. While my motor was being put together in my friends shop, some jerko stole the whole damn engine harness(not computer or mass air system)thank god. So i guess i have no choice but to buy a new one or <gulp> used. Does anyone know where to get an AFFORDABLE engine harness. I want to get the painless wiring engine harness but i heard there no good. No offense but i cant deal with thirdgen resouse. Any other places. please for the love of god help.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 19, 2001 | 01:21 PM
vortech305's Avatar
someone PLEZZZZZZZZZZZZZZZZZZZ!!!!
Old Mar 19, 2001 | 01:56 PM
theformula's Avatar
Why don't you ask your "friend" if any of his friends own F-bodies or similar setups where they could of used your harness. Sometimes you don't know people as well as you think.
Old Mar 19, 2001 | 04:19 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
vortech: you may want to do a search through the boards, this was a topic not too long ago with discussion of price and reliability.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 19, 2001 | 06:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
https://www.thirdgen.org/cgi-bin/messgboard/search.cgi
Old Mar 19, 2001 | 07:02 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I used the Painless and it's a high quality piece. Mine was just short. Make sure you get the long harness if you use Painless. Their tech dept was excellent.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 19, 2001 | 07:13 PM
Vader's Avatar
Vortec,
Wasn't me. The nearest I've been to Flushing was a trip to the restroom this afternoon (sorry - I'll be t you hear that one all the time).
You might consider checking eBay. I've seen several harnesses, ECM/harness combos, etc. offered there. If one comes up from your area, you might want to inquire... And even if you can find one elsewhere, you might be able to get a deal.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 20, 2001 | 01:37 PM
vortech305's Avatar
Vader ive tried ebay and no luck but rob u say that painless wiring has a longer wiring harness than stock. How much do they go for. As i was told the stock replica from painless is no good and u would have to run the harness to the driver side panel(vise versa) in order for it to fit. Did u have any problems with the harness. In an elapse time how long did it take to hook up everything.
92' camaro
Soon to come!!!
Other car;
Old Mar 20, 2001 | 09:23 PM
custman87T/A's Avatar
I don't live too far from you and am parting out an 86 T/A the wiring harness is there and mint...I don't think it will work for your application though...if you need it drive up and take it out for free.
Old Mar 21, 2001 | 12:31 PM
vortech305's Avatar
hey custman 87 r u serious. Are u willing to give it to me for free. If u r i appreciate it. One prob. i dont know a damn thing on taking a engin harness out. My friend does(he's a mechanic) and works daily so that might be a problem. If its possible can u take it out and ill pay u for it. If u want to take it out how much to u want for it. If u dont want to take it out ill see if my friend could take a day off and pick up the harness, is that ok.
Old Mar 21, 2001 | 02:38 PM
Steve89GTA's Avatar
How about the Yard...there's a billion wrecked thirdgen's up here in Toronto.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 21, 2001 | 10:36 PM
vortech305's Avatar
I live in NYC do u got a number where they can deliver it. By the way custman what type of engine is the harness coming out of. Need info.
92' camaro
Soon to come!!!
Other car;
Old Mar 23, 2001 | 07:14 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Hey vortech you might be able to use that harness out of the 86 but there are some PITA repinnings that will need to be redone. Mike Davis (85MikeTPI) has done it, and he has the whole project mapped out to make it a bit easier for you... here is his website: http://www.ece.udel.edu/~davis/z28/
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Mar 23, 2001 | 07:28 AM
Rob P's Avatar
Engine: ZZ4TPI
Sorry it took so long getting back. My computer lives behind the passengers side foot kick panel, the harness passes thru the firewall below the heater/ac box. Since I didn't know what I was doing when I installed the TPI motor in the car, I went really slow. Probably 2 or 3 days to route all the wires properly. You get a new ALDL and there are connections for the tranny to disengage lock up torque converter when depressing the brake pedal, neutral safety swtich, fuel pump lines. So I pulled a lot of my interior out to run the lines. I'm not sure how long the "long" Painless harness is. However, my wire loom rides over top the a/c thing filled with desecant (cant remember the name, duh!). Not as attractive as I'd like. I think Bernard Tripp, aka Btripp, aka GMTech over on sethirdgen.org acutally cut and lengthened each wire. But he's pretty smart like that. I'd call Painless and discuss it with them. I have my old 92 Z28 engine harness up in the attic but I've cut a few connectors off here and there.
Let me know if theres anything else I can help with.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old Mar 23, 2001 | 12:37 PM
If you need the harness e-mail me ottoman45@aol.com and we can set it up...belive me if I was in the mood to take it out myself I would sell it instead of give it away but I work two jobs and only have the weekends for the house and car. If you want to come by one weekend and get it it is yours.
Old Mar 25, 2001 | 10:54 AM
vortech305's Avatar
gotcha
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
