Having Problems with My Tpi 86 Iroc NEED HELP QUICK
Old May 19, 2004 | 09:57 PM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
Guys. My tpi camaro will start and run fine but it has no power it will only go about 20 mph. It has been sitting awhile and I tried changing all the tune up stuff like cap and rotor and plugs but still the same. Please help me. I need the car tommorow afternoon.
Thanks,
Irocznut
Old May 19, 2004 | 10:40 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
check the fuses?
I pulled a fuse once to disable the fuel pump, wrong one, I took out 1/2 my bank of injectors....
it ran like crap (and I mean crap, speed was difficult) and eventually it wouldn't start....
Old May 19, 2004 | 11:17 PM
Morley's Avatar
if it seems to idle fine but won't carry a load (go when in drive) it may be the Cat is plugged up.
Old May 19, 2004 | 11:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think that after a bit of driving, if you pull th car into a dark garage and peek at the converter, it will have a slight glow if it is clogged up.
I am not sure about the validity of that statement as ive only heard it, never tested it.
Old May 21, 2004 | 11:46 AM
irocznut's Avatar
Car: 1992 Camaro RS
Engine: 305 V-8
Thanks for the tips guys.....It can't be a clogged cat cause that camaro doesn't have one and I found out the distributor was loose and it ould move when in high rpm's so the computer would advance the timing like crazy making the motor not run right.
Thanks You All
TheJoeY88
Aug 13, 2015 06:51 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
