A/C Question
Old May 20, 2004 | 07:42 AM
dp149's Avatar
A/C Question
Question for all the A/C experts. the AC in my 86 ta blow hot air. Now I know the logic of what all the parts do but I am trying to figure out how to start troubleshooting. When I turn the ac on, the clutc on the compressor does not spin. Now I know it won't spin if their isn't enough refrigerant. How involved is it to convert this to r134a? Can I just get one of those goofy kits for $30 that does the conversion and see if it works? or is there much more to it?
any advice would be helpful...thanks...
Old May 20, 2004 | 04:24 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The conversion kit for $30 usually just replaces the fittings and a few seals. They work alright.
If your system truely is low on refrigerent it had to go somewhere. Refrigerant isnt a consumable fluid. Youd have to find the leak and replace the accumulater to be safe.
Old May 23, 2004 | 03:44 PM
Vader's Avatar
A proper retrofit also requires a change of the expansion control and installation of barrier type hoses, and should include an evacuation and oil recharge.
Old May 23, 2004 | 06:23 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
If your car is an 86 you shouldn't need new hoses. Most cars after 85 came with barrier style hoses already installed.
Old May 23, 2004 | 07:25 PM
Vader's Avatar
My '86 T/A didn't. Standard swaged fittings, no seals.
Frozer!!!
Jan 19, 2024 04:55 PM
greenyone
Aug 29, 2015 11:08 AM
redmaroz
Aug 16, 2015 11:40 PM
BikeFarm
Aug 11, 2015 11:35 PM
