cam effecting the module??
Old May 20, 2004 | 08:52 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
would an aftermarket cam affect a magnetic pickup in my distributer causing it to misfire sometimes? ive been though 3 distrubutors and cant lose the misfire or get a constant time. i try to time it and the timiing flashes varies5 degrees each way @1000rpm...???
Old May 21, 2004 | 06:23 AM
ede's Avatar
ede
i'd suspect a timing gear/chain problem or maybe wear on the distributor gear.
Old May 21, 2004 | 01:41 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
the distributors were new and the engine only has 20k on it. i advanced the timing at the crank 4*on install
does tha have anything to do with it.
Old May 21, 2004 | 01:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No the cam cannot cause that.
I'd suspect the timing set. Doesn't really matter if you put it on yesterday; if it shows up as defective, it's defective.
One of those cheap "roller" chains, the ones that are about $20?
Put a crank socket on the crank; rock the crank back and forth while watching the rotor; see how far the crank can move in between where it moves the dist. That will tell you immediately what the chain's condition is.
Old May 21, 2004 | 01:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i was going to suggest the exact same thing.
well, i dont have a crank socket... what i do is take the crank pulley off, then put the bolts partway back in the balancer.
stick a bar, jack handle, piece of wood or something of that nature between the bolts and use that to turn the motor over..
turn it with the cap off the distrib until the rotor moves, then turn the motor the other way.. if theres excessive play there, then get a new timing set.
Old May 21, 2004 | 03:06 PM
ede's Avatar
ede
damn having to do that one time and i'd be buying a socket or flywheel turning tool
Old May 21, 2004 | 03:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
actually, i find it to be easy and MUCH quicker then pulling the balancer off to use a crank nut.
Old May 21, 2004 | 07:15 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
edel timing set dont know if its that but i guess it cant hurt to try.
Frozer!!!
Jan 19, 2024 04:55 PM
angel2794
Sep 8, 2015 06:22 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
crazynights
Aug 21, 2015 06:53 AM
