Block Filler???
Car: 89 IROC-Z
Engine: 383
Block Filler???
Another guy on the boards suggested I use block filler in the water jackets in order to seal the hole I ground into it. Has anyone ever done this?? If so did it work?? Where can I get block filler?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
--RPM Racing--
I don't know all the uses of block filler, but the only time I have heard of it used is on drag cars that only run for a short amount of time. It strengthens the block so that tolerances can be tighter.
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
We have used Moroso block filler on a roundy round sportsman camaro with no ill efects,filled to right below freeze plugs.But if the hole is near a wear surface or stressed part of engine,main caps,etc. Ths is one big if? Look for a industrial shop in your area that does shafts or pumps,and decide if you want to spend the $$$$
skinny z
Oct 5, 2015 06:23 PM
