What is the average temperature for a 5.7L V8?
Old May 21, 2004 | 02:42 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
What is the average temperature for a 5.7L V8? 210? 220? 240? 250?
Old May 21, 2004 | 03:00 PM
ede's Avatar
ede
only had one and it ran 160*F
Old May 21, 2004 | 03:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Around 200* should be normal.
Old May 21, 2004 | 11:33 PM
MdFormula350's Avatar
I found mine to be 220 degrees with stock cooling.
I have had 3 350 tpi thirdgens.
Old May 22, 2004 | 02:37 AM
Morley's Avatar
Stock thermostat in the TPI's was 195, so around 200 would be "normal" on a warm/hot day
Old May 22, 2004 | 12:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Normally with a 195* t-stat, fully functional cooling system and a properly tuned engine coolant temp will range from 200-228*, 215*- 220* is most common.
bjpotter
Oct 4, 2015 07:48 PM
bjpotter
Oct 2, 2015 09:12 AM
ironbmt
Sep 27, 2015 06:00 AM
BWilcox
Sep 20, 2015 12:19 PM
