New oil leak coming from....
Old Mar 26, 2001 | 01:39 AM
IROC-JP's Avatar
Recently I overheated my engine when my tranny would not shift out of first, now I have a nice size oil leak. It is coming from the rear passenger side of the engine above the starter. I have checked the oil pan and it seems fine. I also don't think its the rear main seal, oil pressure sending unit, or dipstick tube. It looks as if it might be coming from the rear of the head. I just tried wiping everything down and I going to wait till morning to see if I see anything. Does anyone have any ideas? I'm hoping maybe just a valve cover leak, could it be anything else?
'86 305 TPI 700R4
Edelbrock headers, highflow cat, borla cat-back exhaust, AFPR, modified MAF,
Stage 2 chip, 1.6 ratio roller tip rockers, b&m megashifter, shift kit, MSD 6AL
Old Mar 26, 2001 | 04:35 AM
Irockin's Avatar
I had a similar oil leak. It turned out to be the oil pressure sending unit. It's on the top of the engine, behind the intake, near the distributor.
Old Mar 26, 2001 | 08:46 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably a valve cover leak... the top of the head gets extremely hot, your VC gasket is probably burned to ash in the middle of the outside rail
ICON Motorsports
Old Mar 26, 2001 | 12:37 PM
IROC-JP's Avatar
Thanks guys, I'll check both.
'86 305 TPI 700R4
TheExaminer
Aug 26, 2015 04:59 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
