Balance, and SCAT cranks.
Old May 22, 2004 | 02:59 PM
devilfish's Avatar
Hello
Im looking at this crank from SCAT http://www.scatcrankshafts.com/stock...tcranks02.html
The "9-10526" - Late Model One-Piece Rear Seal for my 1991 vette.
And to go with this I will use TRW fordge pistons, and stock rods with ARP bolts ( yes resized ).
The webpage say "Balanced and Ready to Install Straight Out of the Box" ? Does that mean it has the same balance as my stock L98 crank? I will of course rebalance the hole rotating assemby cause I got new TRW fordge pistons. But does this mean trouble for my and my mech when its time to balance it? Im I going to need alot of heavy metal due to this??
Old May 22, 2004 | 06:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Yes, neutral balance, as I think all 350 cranks are. You may be confusing this with the oft mentioned 383 cranks.
Old May 22, 2004 | 07:00 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
Late model SCAT cranks have an odd balance....technically they are half internal(neutral) half externally balanced! I ran into this problem when I was trying to get my flexplate. Apparently the front (balancer) is neutral where the back(flexplate) is weighted. I called SCAT and they told me that's how all late-model, 1pc engines are.
As for being balanced out of the box...If you want a reliable motor that puts out the most power, have your entire rotating assembly balanced. They probly mean that it is balanced the same as a stock cranks, and that if you used stock rods/pistons (or a combo that weighted the exact same) then you *shouldn't* have to balance it.
Be safe...have it balanced.
Old May 23, 2004 | 08:37 AM
devilfish's Avatar
Yes my stock crank is zero balanced at the front, but external at ( in my case ) the flywheel.
I will have to rotating assembly balanced. I just dont what to ad alot of heavy metal.
Old May 23, 2004 | 08:17 PM
IROC_385Z's Avatar
Engine: SBC 385
...Then run light rods/pistons
djmarch
May 8, 2016 11:32 AM
LT1Formula
Oct 8, 2015 08:34 PM
monte87cortez
Sep 26, 2015 08:10 PM
camarohelp
Sep 22, 2015 03:19 PM
Magman
Sep 13, 2015 12:14 AM
