head leaking out header bolt
Old May 23, 2004 | 10:47 AM
onebad84z28's Avatar
Car: 84Z28
Engine: 305,s/r torquer heads,cam,headers
Transmission: 700 r4
hi, put some new sr torquer 305 heads on my z28 and now i have coolant leak out of the last header bolt on the driver side. wondering if anyone had this problem or heard of this problem with these heads. summit sending new one out monday.
Old May 23, 2004 | 03:03 PM
Vader's Avatar
I've only worked on one set of Torquer 305/SR heads, so I'm not sure, but it sounds like a defect in the eastern castings.
Old May 24, 2004 | 12:13 AM
onebinky's Avatar
Definately sounds like a casting flaw. I installed the same heads recently and didn't have any issue with them.
Old May 24, 2004 | 11:02 AM
Damon's Avatar
Sounds like the header bolt hole was drilled maybe a smidge too deep and broke into the water jacket. Drain the coolant, dry it out in there the best you can (blow out with compressed air and let air-dry for a few hours). Put some RTV on the threads of the header bolt, install it and torque it down. Problem solved.
Or if you're REALLY into a big job and lots of time shipping parts back and forth, return it for a replacement head.
Old May 24, 2004 | 06:08 PM
Car: 84Z28
thanks for the replys ,looks like drilled to deep so i am going to try to seal it just that way. took it over to friend that help put the motor together he said the same thing,and the leak has almost sealed it self.
Old May 24, 2004 | 06:48 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'm partial to permatex no. 2 rather than rtv.
Old May 24, 2004 | 07:49 PM
rjmcgee's Avatar
I'd be on the phone getting a new head shipped. Seal yours and ship it back when the new one arrives.
Old May 24, 2004 | 11:12 PM
onebinky's Avatar
Is that the red anaerobic stuff? From what I hear, that stuff is great.
Old May 24, 2004 | 11:59 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I'd definetly get ahold of world or the place you got the heads from and try to get a new one. A defective part is a defective part...I wouldn't run it any longer like that because they could somehow say you voided the warranty. World or a supplier definetly owes you a new head.
Old May 25, 2004 | 12:05 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Get a new one comming, don't (but you already have) screw with it so they can see what they did wrong so as to avoid doing it again. Why would you try and fix it? I would be pissed and either get a replacment or get my money back!
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
