Aftermarket Air Condition
Old May 23, 2004 | 06:34 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
What is the best air condition unit (compressor) i can buy for my 87 Iroc? I want something that performas at least as good as stock, for an 88-92 since i will be convertin to serpentine, and one that looks real trick (polished). I need to replace my compressor since it is whining like a b itch, so i figure this is the perfect time. thanks.
Old May 23, 2004 | 10:49 PM
Vader's Avatar
Checked the oil charge lately? That new compressor might not last very long without oil, and the old one may last indefinitely with the correct amount added.
Are you certain the compressor is at fault and not the clutch?
I'd suggest a Harrison R4 compressor, polished or chromed if you prefer. It will easily work as well as a stock compressor.
Old May 24, 2004 | 12:01 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
How would i know if it is the clutch? I know when i turn it on, at about 1000 rpm in moans and groans... the moaning goes away if i sping the motor faster than 1k. Also, where would i check the oil charge?
Old May 24, 2004 | 01:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The moaning is real typical for cars with that belt system (I'm assuming you have one ribbed flat belt, and a V-belt for the A/C). It doesn't indicate that there's anything wrong.
Are all the brackets and bolts there? That's usually what makes it do that.... the whole assembly kind of flopping around out there in space.
Old May 24, 2004 | 08:17 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
But it only moans at about 1K. The moaning is more like a vibrating... sounds like bad bearings. I put the belt on really loose to make sure that i don't seize up the bearing. Did i screw up??
Old May 24, 2004 | 09:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, that's what they do. Between about 800 and 1100 RPM. Tightening the belt doesn't really help, because the actual problem is tha tthe compressor isn't held to the engine very well.
You're probably missing a bracket or a bolt.
There's probably nothing wrong with your A/C itself if it blows cold.
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
jackhammer
Aug 15, 2015 10:04 PM
92purpz28
Aug 11, 2015 02:30 PM
