Lota ticking coming from the engine bay
Old May 23, 2004 | 11:29 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I always hear alot of things going on in there, but sometimes I think its louder than what it should be. I also hear my TB sucking in alot of air which might be good, but it sounds retarded outside the car. Anyways. Its weird, sounds as if its "ticking" under the plenum. Do the fuel rails or injectors make loud audible ticking noises?> What gives? Shes not getting ready to blow is she? Thanks guys
Will
Old May 23, 2004 | 11:34 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
On my 305 TBI, you can hear then injectors but there basicly outside the engine, I would say does it run rough at all, it maybe an intake gasket leak somewhere on the tpi runners or where the base meets the heads. It could be an exhaust leak too, but you said it was coming from the intake.
Old May 23, 2004 | 11:37 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The injectors will tick. BTW, nice body on that car.
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
