I think i have a coolant leak, causing a bad ezhaust odour.
Old Mar 22, 2001 | 10:15 AM
chubb rock's Avatar
I own an 89' IROC Convertible with a 305. When i start the car up in the mornings, there is a strong smell (with the expectant puff of smoke). I know that these cars have a cronic problem, in regards to a little oil leaking into the cumbustion chamber. But the smell from the exhuast is sulphuric, and almost choking. When the engine is hot, you really don't notice the smell, even with the top down. I've been told that it could be antifreeze leaking into the cumbustion chamber. What's the problem? And, would adding another catalytic help any?
Old Mar 22, 2001 | 08:00 PM
rezinn's Avatar
What kind of gas are you using? Some gas has higher sulfur content than others, in California it isn't much of a problem because there is very strict regulation. Antifreeze doesn't really smell like sulfur, you will know when you have an coolant leak by the smell.. I don't really think it is a problem, but it could lead to a shorter cat life. I really wouldn't add another cat...
You should probably just switch brands of gas.
Old Mar 27, 2001 | 10:31 AM
chubb rock's Avatar
Thanks...I am also told that if I use a thicker oil, it will reduce the oil leaks from those crappy valve seals. I also think my Cat is due for replacement.
Old Mar 27, 2001 | 10:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The sulfur smell is from the cat itself. Usually the smell is a pretty good indication that it needs a new one.
ICON Motorsports
xxx3man`
Sep 23, 2015 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
