Engine Problems
Old May 24, 2004 | 07:11 PM
RachaelRider16's Avatar
Car: 1989 Camaro RS
Engine: 5.0 ltr. 305 TBI stock with holes d
Transmission: T-5 five speed
Engine Problems
Is it possible for oil to shhot out of the dipstick tube if there is too much oil in it? I am at a loss with this one. I really don't want to pull my engine and spent a lot of money if I don't have to.
Old May 24, 2004 | 08:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Usually oil shooting out of the dipstick is caused by excessive pressure in the crankcase. Do you currently have a pcv and a breather installed in the valve covers?
Old Aug 20, 2004 | 02:02 PM
Car: 1989 Camaro RS
Engine problems
Yes, I do have a pcv and breather on my valve covers. Do I need to replace these parts?
Old Aug 20, 2004 | 04:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Damn this is old, it can't hurt to replace them they are really cheap, a couple of bucks. You might also want to replace the grommets also if they are broken or brittle.
You might also have serious engine problems, such as excessive blowby. If you feel ambitious you could do a compression or leak down test.
Old Aug 30, 2004 | 02:43 PM
Car: 1989 Camaro RS
What is excessive blowby?
Old Aug 30, 2004 | 03:18 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
blow by is the rings letting air through into the crankcase or blowing by the rings etc...
Can also be seen as oil blowing by the rings into the combustion area... it will do it to a point, but excess blowby is bad...
Old Aug 30, 2004 | 09:42 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Smell your oil fill hole in the valve cover. If blowby is bad enough to blow out the dipstick your oil should smell like gasoline.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
