How do you identify stock 305 to stock 350 heads?
Old Mar 18, 2001 | 07:04 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
How can you tell if you have 305 heads or 350 on a stock motor? Is there a casting number? I know that you can tell if a block is a 5.0 or 5.7 by looking at the cast number on the back of the block beneath the driver's side head.
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 18, 2001 | 07:09 PM
Camarogofast's Avatar
Pull off the valve covers and there should be a casting # on the head somewhere. If you post it on the board, I have a book with all the casting #'s and I can tell you what it is.
Old Mar 19, 2001 | 12:44 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
And you don't even have to run the #s to find out if it's 305 or 350 heads you're looking at. 350 heads have the casting # in parallel with the long plane of the heads. 305 heads have the casting # written vertically.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Mar 22, 2001 | 09:53 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
THE COMBUSTION CHAMBERS ON A 305 HEAD ARE FURTHER APART BECAUSE THE BORE IS SMALLER.350 POCKETS ARE 1-5/32 APART AND 305 POCKETS ARE 2-1/32 .
Old Mar 22, 2001 | 10:01 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
OF COURSE,IF THE HEADS ARE STILL ON THE CAR ,MY LAST POST IS USELESS.(GOTTA READ QUESTIONS MORE CAREFULLY)
Old Mar 23, 2001 | 08:56 PM
Omar's Avatar
Joesph, take off your valve cover, and you should see your casting number. For L98 iron heads, they should be 14101083.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Mar 27, 2001 | 03:16 PM
I finally got the chance to pull the V/C's off the car and the cast number reads 10110810 on the head and it is written vertically, parallel to the short plane of the head. Does this mean that I have 305 heads on the car? Should I scrap these heads because they are hurting my performance? Do these help me at all in gaining a couple of points of compression because the combustion chambers are smaller? I did have a rebuilt engine installed a few years ago (a rod went through the block on the original one). Is it possible that the rebuilders used 305 heads during the rebuild?
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
marcusaw
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 8, 2015 01:18 AM
Leggman1
Aug 6, 2015 04:15 AM
