why is my t.....?
Old May 24, 2004 | 08:18 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
why is my t.....?
dudes i think my timing is off. how can i tell if so? my rpms go up and down somtimes. TPS is ajusted and new IAC
Old May 24, 2004 | 08:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: why is my t.....?
Did you adjust the IAC? What motor do you have? Checking and adjusting the timing is a piece of cake.
Old May 25, 2004 | 04:50 AM
ede's Avatar
ede
you can tell your timing is off by checking it
Old May 25, 2004 | 10:57 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
at the time i thought it was no ajustment and today still dont know. please tell me how to ajust it on a 2.8 89 camaro. ill love u for this.
Old May 25, 2004 | 11:12 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
pick up a 82-92 Haynes manual. I hear they tell you how to set the timing.
In general, yank the EST wire (if so equipped)
loosen the distributor hold down bolt
start the car
point timing gun at balancer ands pull the trigger, i think you have one line that is distinctly thicker than the rest....
rotate distributor until desired timing is reached.
Old May 25, 2004 | 12:56 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
thanks. what about the IAC ajustment?
IceManRS305
96
Feb 8, 2008 06:47 AM
IceManRS305
Dec 13, 2006 06:00 PM
IceManRS305
Aug 14, 2006 10:19 PM
1981TTA
153
Jun 28, 2006 09:45 AM
badgta
Apr 29, 2003 03:09 PM
