Changing the Master Cylinder, any tips?
Old Mar 27, 2001 | 07:19 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
My car aint stoppin right. There are no leaks, (the MC resivior is full of brake fluid...) so I am gonna change the master cylinder.
Any body got any tips for me before I dig into this this afternoon? I have been told that it shouldnt take more than an hour to do.
Thanks!
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Mar 27, 2001 | 08:16 AM
tregnab's Avatar
Fairly easy job. Make sure to bench bleed the new Master Cylinder. Don't do the bench bleed on the car, do it in a vise like the instructions say. This step is critical
Use a brake line wrench on the fittings to make sure you don't round a nut.
When I changed the Master Cylinder on my car a while back, I also took the proportioning valve off, took the springs out, and blew compressed air through it. After that, my car now stops like never before. I think the previous owner must have poured dirty fluid in the reservoir or something, because there was a little gunk in there.
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
Old Mar 27, 2001 | 10:00 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Well,
I also have very few tools here with me, so I dont have a vise!
I wish that I could do the compressed air thing too.....
Any other advise?
Old Mar 27, 2001 | 04:08 PM
tregnab's Avatar
hmm, well, the vise is used to hold the new master cylinder stationary so that you don't spill fluid while pumping the piston with a screwdriver. You could probably jimmy up some way to support the cylinder, maybe using a wall or something to push against if you don't have access to a vise.
compressed air is the only way I know of to clean out the proportioning valve though...
Michael Bangert
mbanger@iupui.edu
'88 5.7 IROC
'99 CBR1100XX
'00 Silverado LT
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
