0 compression
Old May 25, 2004 | 05:16 AM
84_berly_84's Avatar
Car: 84 berlinetta
0 compression
whats this mean my motor was rebuilt about 2 years ago and we just got around to putting it in. well I had spark, fuel, timing is correct. but no start so I put a compression tester on it and it says zero. all I checked was #1 and 2 cylinder then I got frustrated where do I go from here
Old May 25, 2004 | 05:54 AM
ede's Avatar
ede
back the rocker nuts off a turn or two
Old May 25, 2004 | 12:36 PM
Lionsden's Avatar
Sometimes over looking the simple stuff can cause a lot of extra work. Verify that the compression tester is working correctly.
Old May 25, 2004 | 02:50 PM
ede's Avatar
ede
yeah damn if i didn't have that happen to me with a tester from sears. compression leaked off after it peaked. ended up buying one from snap on and got steady readings with it.
Old May 25, 2004 | 02:51 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Are you sure both valves are shut while testing it?
Old May 25, 2004 | 05:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You are holding the throttle open too right?
Old May 25, 2004 | 07:30 PM
Car: 84 berlinetta
ok explain to me the proper way to use the compression tester?
ill try the rocker arms too.
Old May 25, 2004 | 08:06 PM
Air_Adam's Avatar
TTT
Old May 26, 2004 | 12:46 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Like they mentioned make sure the rocker arms aren't to tight.
Remove all the spark plugs and remove the coil wire so the car will not start. Wire the throttle blades open.
Screw the compression tester into the spark plug hole. Crank the engine over for a few seconds. Record the reading and do that for the rest of the cylinders.
Old May 26, 2004 | 05:06 AM
Car: 84 berlinetta
thank-you ill give it a try...
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
