Will I pass?
Old Mar 27, 2001 | 10:24 AM
Steve89GTA's Avatar
Will I pass?
89305TPI. New dynomax cat, new plugs, new fuel filter, clean airfilter, clean IAC and TB, removed A.I.R system...pump still on though. (I removed the lines to the exhaust manifold...no visuals here in Toronto).
Will I pass??
Car smokes slightly at startup occasionally but otherwise idles perfect and runs great.
Thanks for your input!
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 27, 2001 | 12:25 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
Probably, I wasn't able to get my carb. engine to pass without the A.I.R. hooked up though.
Old Mar 27, 2001 | 02:43 PM
Steve89GTA's Avatar
Any other inputs from TPI guys? I don't have my diverter valve...does it allow oxygen to enter the cat when car is fully warmed?...I'm guessing that's what it does ... and during cold operation after startup, it allows air into the exhaust manifolds?
Thanks for you help
Old Mar 27, 2001 | 05:39 PM
evilho7810's Avatar
My friend tried to pass with no air pump and made almost a 50 on the Hc. The standard was a 1.5 at the time now it's a .8. I doubt you'll pass without the air setup. You can try to pour some denatured alchohal in your gas tank.
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
