Code 22 and code 34
Old May 25, 2004 | 11:07 AM
DJXero's Avatar
Car: 1992 Camaro Z28
Code 22 and code 34
I've got a serious problem. I can't keep my car running. It's got a hard time starting, and I have to keep gas on it to even keep it running, if I let off the gas, it falls to 500, then dies. The SES light wasn't on when it was running, but I put the little scantool( I didn't buy it, but may as well use it) and 2 codes flashed, 22 and 34. I understand that it's the TPS and either the EGR or the BARO, but would either (or both) of these codes cause the car to fun like garbage and not stay lit? Any help or pictures to point me in hte right direction would be very appreciated.
Old May 25, 2004 | 12:54 PM
DJXero's Avatar
Can anyone help?
I got it started this morning, but it's running extremely rich and has some trouble moving from a stop. It seems to struggle a little, then picks up and goes, but it smells kinda like unburnt fuel, but different than what it smells like at a gas station or in a container. What's the deal here? Please help!!!
Old May 25, 2004 | 01:33 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
code 22 is TPS too low and 34 is Map sensor voltage high - prssure high/vacuum low. For the 22 make sure the voltage is at .54 with throttle closed. For the 34 make sure the sensor is plugged in and is getting a vacuum signal from the intake manifold.
Old May 25, 2004 | 01:51 PM
DJXero's Avatar
Would either of those two situations cause it to run like it is?
Old May 25, 2004 | 02:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes but more so because of the MAP than TPS.
Old May 25, 2004 | 03:02 PM
DJXero's Avatar
I know this sounds dumb, but is there a specific way to check for this? i don't have a lot of experience with the map sensor :-(
Old May 25, 2004 | 05:47 PM
DJXero's Avatar
ttt
Should I just replace the sensors and hope for the best, or is there a way to see if the sensors (Especially the map) are faulty?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
