URGENT vacuum line, where should it run to
Old May 25, 2004 | 09:53 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
The car is a 1990 L98. Was changing spark plugs and noticed that directly between the 6 and 8 plug (i think its 6 and 8 passenger side 2 closest to the passenger compartment) and about a half of an inch up there is something that screws into the head that has a connection that could only fit a hose that im assuming is some sort of vacuum line? But nothing is attached to it should there be?
Old May 25, 2004 | 10:08 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
here is a picture taken of it from underneath the car
Old May 25, 2004 | 10:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That isn't a vacuum thing; it's the fan switch. There should be an electrical connection there.
Old May 25, 2004 | 10:48 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
primary or secondary fan? because i have no overheating problems
Old May 25, 2004 | 11:22 PM
onebinky's Avatar
Primary IIRC, secondary is controlled by the ECM.
Definately the fan switch though, looks like the plastic skirt on it is broken off though. New one from napa is about $20.
Old May 26, 2004 | 10:15 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
save your 20$ and get a cable lug. works fine and costs almost nothing.
Nebu.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
apie2546
Aug 10, 2015 05:43 PM
