Modified Air Intake ????
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
I have done a search and to no avail. I was not able to find answers to what I am looking for. So, does anyone have any pics of a modified stock firebird air intake housing? I want to do this simple mod, but would like pics so I can see exactly how it is to be done.
TIA
John
TIA
John
Car: 1988 GTA
Engine: 5.7L/L98
If your looking to modify your stock setup, first thing to do is buy a K&N, then simple with a circle saw maybe a 1-1.5" and drill some holes in it to increase flow. Some people have cut away the bottom or sides but the hole saw method works well and is fairly easy. I just added a whole new section of tube to replace the stock piece that has an open element on the backside.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Engine: 5.7L TPI
Originally posted by 84customZ28
did you have to move your battery to another spot? I thought about doing that same set-up....but..I don't feel like moving my battery somewhere else...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
on camaros its on the passenger side...
you could do the mirror image of what he has...
athough, the stock camaro TPI intake flows great already.
Car: 1988 GTA
Engine: 5.7L/L98
Yeah the Camaros stock intake was the reason they were rated 5HP higher than the Firebird, they breath a little better, still room for improvement. Battery is on the drivers side as stated. What is good about this is I did not have to move my smog canister. Eventually I will add a little more tubing and cut a hole through the sheetmetal right underneath that cannister to extend it down and make it a true CAI.
Engine: 5.7L TPI
has anyone done the airbox mod that is in the tech articles? that is what i want to do but would like to see the "windows" that are cut in the airbox.
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
